yo KEVIN,
I have the 96 Bronco WORKSHOP Manual Testing in my site @
http://www.broncolinks.com/index.php?index=921
Unfortunately
Same as your year
For Example;
A1 VERIFY POWER AT LOAD SIDE OF FUSE PANEL
Key to RUN.
Using Rotunda 88 Digital Multimeter 105-00053 or equivalent, verify system voltage at the load side of fuse
Key to RUN.
Using Rotunda 88 Digital Multimeter 105-00053 or equivalent, verify system voltage at the feed side of the fuse.
(they are checking for power and fuse condition of course, but also for a loose fuse or socket and so on. A loose fuse (internally and ext at contacts) has been known to occur due to prev owners or shops use of screwdrivers or pry bars to remove a fuse...lol; right! I have seen some use a flat blade screwdriver
Also see Testing & Connector Pin-Outs in 92-96 Bronco; Sender Range: Full = 160 Ohms; Empty = 16 Ohms;
http://www.supermotors.net/registry/media/744437
"... gauge that pegs past full indicates an open circuit (broken wire; unplugged connector; corroded terminal; burned sender) on the Y/W wire.
gauge that pegs past empty indicates a short to ground (pinched to the frame, body, or dash supports) on the Y/W wire, OR a sunk float.
gauge anywhere in between that doesn't move indicates an open circuit (blown fuse; corroded terminal) on the power (battery) side of the gauge OR a bad instrument cluster ground at C251 pin 9.
The terminals of C251 (& C250) are known to corrode & lose contact. Polish both the connector pins AND the film circuit pads with brown paper or a pink eraser. The larger version of C441(WPT454) was used until 93.
The level sender can usually be disassembled & repaired by bending the wiper arm inside the plastic housing to apply slightly more force..." by Steve83
