YO WileE7
The 90 speedo gears are in transfer case tailshaft; Fred; 92-96 have the PSOM w/no gears nor cable for speedo/odometer
Ford dealers will have them as well as;
http://www.fordracingparts.com/download/charts/142.pdf
http://www.summitracing.com/search/Department/Gauges-Accessories/Part-Type/Speedometer-Gears/'>http://www.summitracing.com/search/Department/Gauges-Accessories/Part-Type/Speedometer-Gears/
And this is by Fred
also
Gear Change Calculator w/Ford Part Numbers, Colors, & Tooth Count
Source: by Chris B (Blue, bronco boy) at
http://www3.bc.sympatico.ca/cbradley/speedogearchange.html
Use the following formula to calculate the Tire Rev. per Mile for the above formula.
Tire Rev. per Mile = 20168
Tire Diameter (inches)
Automatic Transmissions with 7 Tooth Drive Gear
1983-1989 Automatic Transmissions
Part Number
Description
D0AZ-17271-A
2.73 Gear Ratio / Blue 16 Speedo Gear
C7AZ-17271-B
3.08 Gear Ratio / Gray 18 Speedo Gear
C7VY-17271-A
3.27 Gear Ratio / Tan 19 Speedo Gear
C8SZ-17271-B
3.55 Gear Ratio / Orange 20 Speedo Gear
D0OZ-17271-B
3.73 Gear Ratio / Purple 21 Speedo Gear
Jeep Part #j3167393
4.10 Gear Ratio / White 23 Speedo Gear
Automatic Transmissions with 8 Tooth Drive Gear
1990-1998 Automatic Transmissions
Part Number
Description
C7AZ-17271-B
2.73 Gear Ratio / Gray 18 Speedo Gear
C8SZ-17271-B
3.08 Gear Ratio / Orange 20 Speedo Gear
D0OZ-17271-B
3.27 Gear Ratio / Purple 21 Speedo Gear
Jeep Part #j3167393
3.55 Gear Ratio / White 23 Speedo Gear
Jeep Part #j3167393
3.73 Gear Ratio / White 23 Speedo Gear
Jeep Part #j3167393
more LINKs in my site @
http://www.broncolinks.com/index.php?index=431
