electronic 4x4
cszalai
I am wondering.... on my 94 Bronco around the rear driveshaft output there is a thing with 3 wires on it and they attach to a ring looking thing and the drive shaft goes through the middle of it what is that and what does it do..... My truck won't go into 4x4 and i am sure its the motor but.... there are these 3 wires that are on the motor side of the harness.... I was told it's nothing just cut the wires.... but i haven't been able to find out what it is..... If it is really something not needed can i remove it with the 3 torx bolts holding it and remove it... I can take a picture if you want... but i am sure someone here knows what it is
yo cszalai,
at the Plug...10 wires total.
three of those wires go off to a seperate plug on the Tcase. The remaining 7 wires all go up in a bundle until they split and 4 go to the position selector, and three to the motor(Orange & Yellow) & magnetic clutch (Brown)
Pic by our Sponsor, Jeff's Bronco Graveyard
Following pics by drinkbrew
http://i71.photobucket.com/albums/i160/drinkbrew/2011-06-03195336.jpg
magnetic clutch (Brown) wire
http://i71.photobucket.com/albums/i160/drinkbrew/truck/1267164445.jpg
http://i71.photobucket.com/albums/i160/drinkbrew/truck/1267164510.jpg
In Diagram c11461b below;
7017 Input Shaft
2 7A398 Front Planet
3 7100 High-Low Collar
4 7177 Sprocket, Drive
5 7G361 Electromagnetic Clutch
6 7106 Lockup Sleeve
7 7D126 Lockup Spring
8 7061 Output and Fifth Gear Drive Shaft, Rear
9 7289 Shift Fork, 4WD
10 7219 Lockup Release Spring
11 7G360 Transfer Case Shift Motor
12 7A029 Drive Chain
13 7061 Output and Fifth Gear Drive Shaft, Front
14 3B396 Hub, Auto Locking
15 7N095 Shift Shaft
16 7W074 Range Shift Spring
17 7289 Shift Fork, Range
Wiring Diagram
C
cszalai
the second picture is what i am talking about .... them 3 wires are on the motor side of the plug http://i71.photobuck.../1267164445.jpg
and to disconnect or change the motor them 3 wires have to be cut.....
When i get home tonight ill take a picture and post it
Sgariffo
