twin stick for diff
hot750four
Hi can someone tell me why i need a twin stick to shift my diff ?? thanks so much
Hi 750, welcome..!
There is no "shifter" for the diff's on these rigs.
If your '66 is stock for the most part., you likely have a "T" shifter for your "transfer case". (pretty sure this is what you're talking about)
"T" shifters work fine when clean, oiled, maintained.
Twin stick shifters are a "step-up" in that you can pick-n-choose the gearing front & rear. For example, you can choose to run front only (2 wheel dr.) low range..!! >:D< <'>
bigbluebronc
ca
I was a ******** with my bronco, I ran rocks and sand and snow,if you do stuff like me the twin stick made a a good front digg and a rear push,,,, if you have the lockers.....
BBB
Fryman22
