yo Lotus,
DTC 63 Throttle Position Sensor (TPS) voltage too low; Bad or misadjusted TPS, TB base idle mis-set; binding throttle cable. Suspect open TP sensor, or wiring/harness issues such as connector/terminal corrosion, etc.
A NON-Ford NEW TPS failure is sad to say, a common nuisance; I had a new switch fall apart in my hands recently, as well as other crapola parts from CH...
TPS is located on the end of the throttle shaft on the throttle body (TB)
pic by SeattleBronco
Also TSB 89-14-07 TPS Screws
Publication Date: JULY 14, 1989
FORD: 1983-89 CROWN VICTORIA, MUSTANG, TEMPO, THUNDERBIRD
1984-89 ******
1986-89 TAURUS
LINCOLN-MERCURY: 1983-89 CONTINENTAL, COUGAR, GRAND MARQUIS, MARK VII, TOPAZ, TOWN CAR
1984-87 LYNX
MERKUR: 1985-89 ALL MERKUR LINES
LIGHT TRUCK: 1983-89 ALL LIGHT TRUCK LINES
ISSUE: All Throttle Position Sensor (TPS) mounting screws have a "Pozidrive" head. The "Pozidrive" head looks a lot like a Phillips ***** head. Use of a Phillips head screwdriver to remove a "Pozidrive" ***** will normally result in a rounded or damaged ***** head. Many technicians think it is an overtorqued or "frozen" *****. An adhesive was also used as a thread sealant starting with the 1988 model year. This adhesive requires still more effort to loosen and remove the *****.
ACTION: To prevent rounded or damaged ***** heads when servicing the TPS mounting screws, technicians should always use a #2 "Pozidrive" screwdriver.
READ MORE & See Diagrams
by miesk5 @
http://broncozone.com/topic/14269-code-reader/page__st__40
Testing in 5.0 & 5.8; "...Symptoms of a BAD TPS: The one thing that you can definitely count on, when the TPS fails, is the Check Engine Light shining nice and bright to let you know that there's a Diagnostic Trouble Code stored in the Fuel Injection Computer. Here are some specific symptoms you'll see: 1.TPS Diagnostic Trouble Codes: (DTC’s) stored in the vehicle’s computer’s memory. Code 23: Throttle Position (TP) Circuit Performance Problem. Code 53: Throttle Position (TP) Circuit High Input. Code 63: Throttle Position (TP) Circuit Low Input. Code 121: Throttle Position (TP) Circuit Performance Problem. Code 122: Throttle Position (TP) Circuit Low Input. Code 123: Throttle Position (TP) Circuit High Input. 2.Really BAD gas mileage. 3.No power as you accelerate the vehicle. 4.Hesitation when you step on the Accelerator Pedal. There are times when the ECM (Electronic Control Module = Fuel Injection Computer) will think the TPS has failed when it hasn't. This usually happens when the ECM spits out several Diagnostic Trouble Codes at once.. and so what will save you time, money and the frustration of replacing good parts, is to test the Throttle Position Sensor..." READ MORE
Source: by easyautodiagnostics.com @
http://easyautodiagnostics.com/ford_tps_4.9L_5.0L_5.8L/bad_tps_test_1.php
Location & Replacement pics by Xris at
http://www.supermotors.net/clubs/superford/registry/5183/29981http://broncozone.com/topic/14269-code-reader/page__st__40
via Chilton for your year
1.Disconnect the TP sensor wiring harness.
2.On 5.0L and 5.8L engines, it may be necessary to remove the throttle body. On all other engines proceed to the next step.
3.Disconnect the wiring from the sensor.
4.Matchmark the TP sensor and throttle body. Remove the 2 retaining screws and the sensor
WARNING
Slide the rotary tangs into position over the throttle shaft blade, then rotate the TP sensor CLOCKWISE only to the installed position. Failure to follow this step may result in high idle speeds for 5.0L and 5.8L engines.
5.On 5.0L and 5.8L engines, position the TP sensor so that the pigtail points toward the IAC valve.
6.Secure the TP sensor to the throttle body with the retaining screws. Tighten to 18-27 inch lbs. (2-3 Nm) on 4.9L engines or 11-16 inch lbs. (1.2-1.8 Nm) on 5.0L/5.8L engines.
7.If applicable, install the throttle body.
8.Connect the wiring.
9.Connect the negative battery cable
