B-Co Kid
- Joined
- Oct 14, 2010
- Messages
- 235
- Reaction score
- 8
So, my horn works..with the engine running, but only works intermittently, or rather sluggishly, when the engine is off. and i also hear a click from the horn relay under the dash. I thought it was the horn itself, but when i jump the horn from the positive battery terminal to the positive terminal of the horn, it sounds like it suppose to. LOUD. so i dont think the horn itself is bad. then i tested the positive wire to the horn, it gives just about 12v with the key on and horn depressed. so im guessing it is the relay, but the relay is fairly new. or either a bad ground, but i dont know how to test if it is not grounded correctly. i did, however, put a jumper wire to the positive terminal and run a ground wire to a small ***** located on the horn (that i assumed could be a ground), still did not work. does anyone have any suggestions??
