Low Idle
tship87
Maryland
Ok here's the deal. 94 bronco 351w - When the truck is in park it seems to idle fine. Once it's in drive, it begins to idle lower than normal. It'll fluctuate between 500 and 800 rpms. I've replaced the TPS sensor, O2 sensor, and am in the process of changing the EGR valve sensor. They all may be small issues surrounding the bigger issue but I would appreciate any input anyone has as to what else could be wrong. Also, I had a stock exhaust replacement (just the pipes from the cat-back) and removed the muffler. Could there be a back pressure issue that could cause low idle? Should I put a muffler back on? Thanks.
Tom
yo TOM,
Try a Self Test for Diagnostic Trouble Codes (DTC)s by my pal, BroncoJoe19
http://broncozone.com/topic/14269-code-reader/page__pid__74587__mode__threaded
Run it around to heat the engine up and shift thru all gears incl Reverse. Then turn off all accessories/lights, etc.
Do Key On Engine Off (KOEO) portion first.
Look Codes up in my broncolinks.com site using the new Search function.
And Post em here according to:
KOEO
KOER
Here are the possible causes
StallsAfterStartStallsorQuitsonIdleRollingIdleRoughIdleIdleStallsorQuitsonDeacceleration.JPG
If no codes in KOEO or KOER, check for vacuum leaks
Vacuum Leak Test; On an idling engine check for vacuum leaks using a mechanic's stethoscope with the probe removed, or a ~3' garden hose section. BEWARE of fab, belts, pulleys and hot engine/hoses.
On COLD ENGINE only, use propane torch w/rubber hose attached, UNLIT (have fire ext @ hand for all tests)
or spray carb cleaner, when it gets to the the leak the RPMs will rise.
Also check: vacuum hoses; intake manifold gasket & throttle body and lower intake;
intake manifold gasket & throttle body (Worn throttle shaft) and lower intake; & vac tree
Vacuum Tree Location pic in a 94
vacuum_lines.jpg by joelb23
PCV damaged or vac line leak
- pic by Bbronco311
Air Diverter Valve (AIRD) from TAD Solenoid & Air Bypass Valve (AIR BPV) from TAB Solenoid or a Air Bypass Valve (AIR BPV) & Air Diverter Valve (AIRD) Combination located behind the intake manifold
vacuum reservoirs:
EGR Sys Vacuum Tank & 2ndry air (VRESER - looks like a coffee can in earlier years & often rusts out causing vac leaks; but later years (at least 92-96, may have the plastic type reservoir);
Depiction & Location in Parts Break-Out Diagram in a 96 w/Ford part numbers
Source: by Ford via miesk5 at http://www.broncolinks.com/gallery_images/96TABTAB5.0.jpg
Thermactor Air Bypass Solenoid (TAB, AIRB, AM1) w/Pink vacuum line & Air Bypass Valve (AIR BPV) & Thermactor Air Diverter Solenoid (TAD, AIRD, AM2) w/Yellow vacuum line & Air Diverter Valve or Air Control Valve (ACV) see my site @ http://www.broncolinks.com/index.php?index=416 & EGR Vacuum Regulator (EVR); also called EGR Vacuum Solenoid & EGR Valve Position (EVP) - MIESK5 NOTE: EVP is used on all years except for 95 5.8L California models & all 96, they use the DPFE Sensor instead of EGR Valve Position Sensor (EVP) etc,
Check vacuum hose; & valves for damage
AC, heater, defroster, vent control ckt & vacuum tank (plastic ball, or an irregular box glued to the evaporator cover), under dash & lines to heat/blend/etc. doors; & HVAC vacuum reservoir;Check Valve & Tank Location pic in a 93; "...valve is about a foot down the vacuum line coming off the 'tree' on the engine Plenum. One of the lines on the check valve tee goes to the built-in reservoir on the a/c box, the other into the loom with the white tube heading for the control panel inside ..."
hvac Check Valve and Vacuum Reservoir Location pic in a 93 by garymunson.jpg
Carbon Canister (Charcoal Canister, Vapor Canister, Evaporative Emission (EVAP) Canister for the Evaporative System (see http://info.rockauto.com/Motorcraft/CX1118.jpg)
Fuel Pressure Regulator (FPR): check vacuum line...pics in a 94
by 1994xlt (Cole R) at http://www.supermotors.net/registry/5978/20463
and line to & Cruise Control sys in 86-91
leaky O-rings around the fuel injectors are allowing air to leak past the seals.
& Line to & the power brake booster and booster itself
Vacuum Gauge Diagnosis
"...The vacuum gauge should show 18-22 in-Hg @ idle, and maintain a steady needle. Rev it up to ~2500 rpm, hold it steady, and you should see the needle drop, then slowly increase to a level close to the idle reading (though slightly lower is normal)..."
Source: by SigEpBlue (Steve)
http://www.classictruckshop.com/clubs/earlyburbs/projects/vac/uum.htm
The vacuum gauge should show around 18-22 in-Hg @ idle & maintain a steady needle. Rev it up to ~2500 rpm, hold it steady, and you should see the needle drop, then slowly increase to a level close to the idle reading (though slightly lower is normal). by CRAIG
Suggest buying a vac gauge, best low cost test and MPG helper you can spend $ on;
pic; "...I have a vacuum gauge mounted right in the dash of my truck. I use it to also help determine the load my engine is under while driving, and to estimate fuel economy..."
Source: by William T at http://www.fordf150.net/images/mytruck/vacgauge.jpg
  • StallsAfterStartStallsorQuitsonIdleRollingIdleRoughIdleIdleStallsorQuitsonDeacceleration.JPG
  • hvac Check Valve and Vacuum Reservoir Location pic in a 93 by garymunson.jpg
DNBELOWBRONCO
CALIFORNIA
So how'd it go Tom? Did you fix the low idle problem? I'm always curious when someone asks a question but then we never hear anything about it. So what happened? You said you replaced the TPS (throttle positioning sensor) (base#9B989) but what else? The tech's I've delt with usually replace the TPS sensor and the IAC valve together because they flag the same code, IAC being (idle air control) (base#9J460). If you haven't tried that give it a shot...... >:) -Kevin-
T
tship87
Maryland
Turns out the fuel pressure regulator failed. Replaced it and problem fixed. I had replaced just about everything (plugs/cables/IAC/TPS/fuel filter) and now it runs great.
Utahstroke
