Early Bronco Leg Room
JGunn
Considering buying a 71-77 bronco to restore. Haven't sat in one since I was a kid. I am now 6' 6" and am curious about the leg room in these early models. Is there ample of if not, can the rails be moved back to create more space?
sandman90
Laurel,DE
Hi JGunn, I am the proud owner of a '76. I am 6'3and have Corbeau Baja SS seats mounted in the stock position and I have no problem with leg room.But I don't see why you couldn't move the mounting rails back a little if need be.
VA Ray
JGunn,
I am 6'-6", and I had to adjust slightly the location of my seats for the legroom. I weight about 280, and wanted a little room from the steering wheel as well. Was spoiled by the room in my F-250.
msgsnprtom
