*broncoXLT
Hi all! /emoticons/[email protected] 2x" width="20" height="20" />
So I've got a set of Flowtech headers that are shot. I don't want these again! So I want new ones and have been told to spend a little more money and put "good" headers back on the truck instead of manifolds. I've got an 88 true duel 351 fullsize Bronco. Now, what I need help with from all you experienced header peeps is this: Do I go with headers? If so, what are considered good? I know ceramic coating would be a good idea, right? Who has had good luck with what brands? Which brands seems to withstand the most abuse and are the most reliable?
My truck sounds pretty bada$$ even with the leaking exhaust and I don't want to alter the sound too much. I don't have cats, but am running straight pipe out. I'd be willing to keep up with the maintenance of tightening/checking bolts.
If you've got any suggestions or advice, please let me know! >< <'>
Thanks so much!
Adrienne /emoticons/[email protected] 2x" width="20" height="20" />
Thanks so much!
