under cap condensation
JMo3Stix
Parma Heights, OH
My buddy @ work traded for my brothers 95 xlt. When it's cold or rainy, he's getting condensation from the roof of the cap (so he says), causing his carpet to be wet. It sounds like weatherstripping/seals to me. Any other reason it would be doing this? Doesn't sound like there could be any other reason, unless his floorboards in the rear are shot and the moisture is coming from below, not above.
Where under the cap? Back by the passenger seat? If so, I would remove the trim pieces and try snugging up on the front bolts, (loosen the side bolts first so it will slide forward as you tighten the bolts around the cabin roof. It could be the seals, but usually, unless you have had the cap off they will still be good. If it is near the tail gate, remove the strip that holds the rug down and look under the rug for rust through.
J
JMo3Stix
Parma Heights, OH
It was originally my brothers. He never had the cap off that i know of, but that doesn't mean the previous owners didn't. I'll Let my buddy know what to check. Appreciate the help man :)>-
Camper (Fiberglass) Roof Seam Crack TSB 95-09-05; Cosmetic cracks may appear in the seam sealer used on the exterior surface of the roof. This occurs because the original sealer was not flexible enough
Source: by Ford via Steve83 (Steve, That dirty old truck) at SuperMotors.net
Also have him inspect cab Roof, Drip Rail & B Pillar for cracks;
Roof & Pillar Cracks TSB 96-20-11 for 80-96
Source: by Ford via Chilton
The repair kit is reported to be obsolete now; but;
Roof & Pillar Cracks Repair info & pics in a 93 Centurion
Source: by John D (Classic) at Superhttp://www.supermotors.net/registry/8794/28733
Lana Kane
