yo J,
WELCOME!
Your 89 has two electric pumps; low pressure boost pump in fuel tank & a high pressure pump mounted on the driver's side frame
TANK Removal & Repairs in an 83 (he did an EFI Swap) Source: by Steve83
Some tips;
Remove batty neg cable
have fire ext and assistant
use brass punch or drift on tanks's 2" Lock Ring
Clean Before opening the tank, buy a NEW O-ring and wash any dirt away from the pump plate.
by Steve83
Hard to Re-Fuel, Gas Station Pump Shuts-Off; "...There is a plastic vent tube inside the filler neck that often gets kinked..."
Source: by justshootme84 (Randy Z, Casual Mudder) at Ford Bronco Zone Forums
V REST Vapor Valve (Roll-Over) Valve on later year Depictions & Location Diagrams in 5.0, 5.8, 7.5, & 4.9;
Get new straps & insulators too;
OUR SPONSOR, Jeff's Bronco Graveyard
Upper Tank Strap, 25-
33 Gallon # 30272
New 1980-96 Ford Bronco Each Price: $15.00
33 Gallon Steel Gas Tank # 30214 New 1980-89 Ford Bronco
Steel 2" Sending Unit Hole Price: $105.00
Aftermarket 33 gallon gas tank with 2" Lock Ring.
31 7/8" x 22 1/4" x 15 3/4"
All gas tanks are engineered to the highest quality standards for peak performance and precise first time fit!
Lock ring and seal sold separate.
Made in Canada.
Other parts recommended:
Sending Unit Lock Ring 2" # 30240 New 1980-89 Bronco Price: $5.00
Sending Unit Seal 2" # 30241
New 1980-89 Bronco Price: $1.00
1980-96 Bronco Gas Tank Breather Valve Seal
# 30259S
New!
OEM
1980-96 Ford Bronco
1980-96 Ford Pickup
Gas tank breather valve Seal
Price: $6.00
Bronco Gas Tank Roll Over/Breather Valve
# 30260
New
1988-96 Ford Bronco
OEM Valve
Price: $45.00
