Bebop Man
A couple of my wheel arches are starting to develop rust. I've held it at bay so far by using POR15 and other similar items, but I know the only way to really get rid of rust is to cut it away and replace the metal. Which leads me to my next project:
I want to cut away the area around the fender that's currently in black. I was going to go with some Bushwacker Cutout flares, but I wanted to save a little on the budget, plus have something more custom. I'm thinking along the lines of flat piece of sheet metal with a lip of around an inch or so. The lip could be bolted to the fender above the cut line, with the leading and trailing edges rounded off and the outer edge covered in some kind of molding. Where I hit a stumbling block is how to make the lip and still radius the flare for a smooth arc. Would a machine / body shop be able to pull off something like that, or am I looking at needing get a piece custom molded and formed?
(I'm going for this type of look around my wheel wells.)
An alternative is to 'notch' the lip evenly so as to relieve the flare so it can be bent smoothly arched, and then the lip will fit inside the wheel well.
As always, pointers, tip, tricks, and other suggestions are welcome.
