Good stuff!
Bronco, Rear from 85 & 90 Owner's Manuals; by Ford & Helm via Keith L (TTB Blows, Bling-Bling) at homestead.com via web.archive.org
REGULAR: (Regular means "open" diff in this context)
13 4.11
14 3.00
16 3.50
18 3.08
19 3.55
LIMITED SLIP:
H3 4.11
H4 3.00
H5 4.10
H6 3.50
H8 3.08
H9 3.55
Bronco, Rear in 76-86
Source: by Bob K at
http://ford.off-road.com/trucks-4x4/tech/bronco-rear-axle-codes-and-ratios-20437.html
Bronco, Rear in 82; 2.47:1 is H7,07; 2.75:1 is 01,H3; 3.00:1 is C2,H4,02; 3.25:1 is H5,04; 3.33:1 is B5; 3.50:1 is H6; 3.54:1 is B7,C7,D1; 3.73:1 is C6,D6; 4.10:1 is C1,D3,D7 Source: by Ford & FORD PICKUP TRUCK RED BOOK, 1946-93 Model Year Including Bronco, Ranger, etc. Overview w/Change via miesk5 at Ford Bronco Zone Forums
Bronco, Rear in 92-96 Source: by vibratesoftware.com
Axle Codes
L - Limited Slip Differential
C - Conventional Differential
Code Ratio
12 2.73C
16 3.73C
17 3.31C
18 3.06C
19 3.55C
24 3.54C
25 4.10C
29 3.55C
35 4.10C
39 3.55C
45 4.10C
49 3.55C
58 4.86C
65 4.10C
68 4.88C
69 3.55C
72 4.63C
73 5.13C
B5 4.10L
B9 3.55L
C5 4.10L
C9 3.55L
D5 4.10L
F5 4.10L
H5 4.10L
F8 4.88L
G8 4.88L
H7 3.31L
H8 3.08L
H9 3.55L
W5 4.00L
Door Jamb Label Axle Ratio Codes in a 96; in 1996 F-150, F-250, F-350, F-Super Duty and Bronco Workshop Manual (SEE Thumbnail pic below)
by drivetrain.comDifferential cover/cover gasket shapes chart
Dana/Spicer Differential Parts illustration showing how to locate the Dana bill of material number is provided. This is a critical number to ensure that you find correct parts the first time.
And as my friend Seabronc mentioned............
I made a mistake 15 years ago by telling someone to use the Driver's side Door Jamb label to ID their Rear Differential (axle, pumpkin type, etc.); turned out that a previous owner had swapped a Dana 60 in place of the stock 8.8
so... a run down; I asked Reggie Jackson what he used to help him validate year/make/ model/and component in general other than a Marti Report and/or a Certified Appraisal Document or Doc from an organization such as National Corvette Restorers Society
So I gathered some of the following to start that process;
TRANSMISSION, Automatic
C6 pattern is is P-R-N-D-2-1
If the shifter has a P-R-N-OD-D-1 pattern, the transmission must be an AOD.
If it has an Overdrive Cancel Switch and a P-R-N-OD-2-1 shifter pattern, then it is equipped with an E4OD transmission
AOD Shift Indicator pic by trigger
E4OD Shift Indicator pic by Chris A
C6 Shift Indicator pic
Source: by miesk5 at broncolinks.com/gallery
You can measure the transmission fluid pan to determine which transmission you have if identification information is not available. A 4R70W transmission pan has an overall length of just under 15 inches, while an E4OD pan is much larger, measuring about 20 inches in overall length.-
But a visual depiction is better!
C 6, AOD E4OD, 4R Pan Identification & Driver Side pic
Source: by technicalvideos.com
http://www.technicalvideos.com/identify_my_transmission.phtml
TRANSFER CASE;
Borg Warner Identification; "...The model number is cast into the rear housing, and sometimes stamped into an ID tag on a tailhousing bolt. This is a 93 EB Bronco1356 ESOF..." Source: by Steve83 (Steve, That dirty old truck) at
http://www.supermotors.net/registry/media/773280
Depictions; 1345, 1350 & 1356 Source: by Ventures Truck Parts and Equipment L.C.
Difference/Measurements, 1356 vs, NEW PROCESS 205 in a 94 Source: by Damon H (Plug Ugly)
NEW PROCESS 203 Exterior Parts Diagrams; Shifter Assembly, Mounts, Transmission Adapter, etc.
Source: by Indybronco
http://www.supermotors.net/clubs/superford/vehicles/registry/media/307046_1
208 Parts Break-Out Diagram
Source: by
http://www.transtarindustries.com/catDownload.asp?ID=661
Atlas 4 Speed pics in a 96
Source: by GKR (Greg R) at
http://www.supermotors.net/registry/12207/67797
ENGINE
5.0 vs. 5.8 (EFI) Identification
Source: by Ryan M (Fireguy50) at
http://web.archive.org/web/20070710100333/http://www.fullsizebronco.com/forum/vbarticles.php?do=article&articleid=7
5.8 Parts Break-Out Diagram, External
http://www.supermotors.net/vehicles/registry/media/624513_1
5.0 Parts Break-Out Diagram, External
http://www.supermotors.net/vehicles/registry/media/624439_1
of course; it could have 460 in there; so I think I have some id info in my site
I have info on other engine sizes and type in my site under ENGINE, V8 or six cylider, and Diesel (yep.. we have a bunch of motivated folks here!
As well as other components/systems
Door Jamb Label (Data Plate, also referred to as the Patent Plate & the Warranty Plate)
As an example, a pic for a 94
Source: by Adrianspeeder (The OJ Special, The Lariat, The Bronco) at
from this Plate; you could assume you have a rear diff code of 19 installed in his Bronco;
Basing on this;
Bronco, Rear from 85 & 90 Owner's Manuals; "Note, I'll add that the axle code for some years (Maybe all ) adds a 2 after the limited slip code if the front is also limited slip. So the code "H9" is a 3.55:1 limited slip rear axle only. "H92" would be a 3.55:1 limited slip on both axles. by ElKabong http://web.archive.o...m/axlecode.html
Source: by Ford & Helm via Keith L (TTB Blows, Bling-Bling) at homestead.com via web.archive.org
CODE 19 = 3.55 ratio
and that would be for a Ford 8.8 diff
Bronco & F Series Differential, Front & Rear Brands in 91-93
http://web.archive.org/web/20020220012159/http://90bronco.homestead.com/axlecode.html
Also, VIN Decoder Chart for 81-86 & 87-96 Bronco & Ford Trucks BEST!
Source: by lmctruck.com
http://www.lmctruck.com/icatalog/fd/full.aspx?Page=11
Build Sheet Information (Ford 999 Report); Fords build sheet reply letter w/original build date, optional equipt., axle ratio, paint color, etc. & Build Sheet; Example of an 85
Source: by equivalent (Beetlejuice) at
http://www.supermotors.org/vehicles/registry/detail.php?id=7497&s=30320#content
Build Sheet (Ford 999 Report) Request Telephone Number 1-800-392-3673
expect it in a month or so from call; unless that Group is now gone due to cut-backs at HQ...
Tranny Code from Door Jamb Label;
See Code Information by Type, Vehicle, Engine, Ratios, Fluid, Shift Indicator Pattern, Code, Pan
http://www.fourdoorbronco.com/board/showthread.php?t=1244
So, Trans code= E, that is an E4OD based on Adrian's Listing and Pan ID
(I have PAN ID info LINKS in my site under Transmission, Auto, E4OD and da 4R..
Also see my site for the PAINT CODE from the jamb label; such as,
Paint Color Code Location, Bronco, 85-96; "...1985 and Newer is on the driver door. There will be a white sticker. Towards the bottom of the sticker in the left hand corner it will say paint. This is decieving because underneath of the word paint is the body style code. What you want is the 2 digits or letters above the word paint..."
Source: by levineautoparts.com
http://www.levineautoparts.com/wherismypain.html
In my site I have some Code info for various years exc 88;
such as
Colors in an 89 (in Dealer Brochure) Source: Ford via Hans Tore Tangerud @ lov2xlr8.no
what else?.. to be continued...
