Hello everyone. Just signed up for the forums. I have a '69 Bronco and have installed a Centech BR-10 wiring harness. I was checking all of the connections and noticed the voltage regulator was warm/hot with the ignition switch turned off. The engine had not been running. In talking to Jim at Centech on the phone, he told me to see if there was battery voltage at the green REG S wire coming from the regulator. Indeed there is and should not be according to Centech. Jim did not have an answer on where to go from there. Does the starter solenoid possibly play a part in that? Where does the green REG S wire go in the rest of the harness? Where could the voltage be coming from? Additionally, The starter solenoid did stick twice while attempting to start and I had to disconnect the negative cable from the battery. Any suggestions and advice will be greatly appreciated. Thanks Jeff
