Krafty
Howdy Folks. Back to my No start problem I had before my stalling while driving problem. 93 4.9
Gonna run a bunch of sensor tests this afternoon, but my question is this.
Can a fuel pump be running and still produce low pressure? I always figured as long as it was on it would be working properly.
I don't have a fuel pressure gauge and my valve on my fuel rail is really hard to get to for some reason. I believe its under the intake manifold at the rear of the engine. is there a way to test it without buying a gauge?
p.s it was stumbling sometimes and fired/ backfired when I turned back the key from start to run also.
going to check map, icm, coolant sens, O2 , tps, iac,
disconnected battery after it drained from failing to start for 10+ min so comp should reset.
