roadkingg
Hey all, I need some advice. I've replaced my turn signal switch and flasher due to my turn signals not working.
After the install of the new switch the turn signals still don't work. Fuse is fine. The 4 ways do function as does the horn - I'm assuming my new switch is fine. My old switch was physically broken.
I've attached the only wiring diagram I have and my question is this: Should the LT Blue wire coming from the flasher be hot all the time,when the key is on, or only when the turn signal is activated.
Please excuse my wiring ignorance. :wacko:
