Here ya go; look @ the MAF Swap LINKS in my site @
http://www.broncolinks.com/index.php?index=209
Such as;
Speed Density to Mass Air Conversion & Parts List with Cost for Bronco & F150 Source: by Ryan M (Fireguy50) at fordfuelinjection.com
and;
Speed Density to Mass Air Conversion & Parts List in an 89 F250 351W
Source: by itsacrazyasian Thanks to Fireguy for his info on his webpage full of great info.
What had always worried me was the wiring for the injectors which proved to be very straight forward.
This is the old speed density 351 pinout
For anyone contemplating the swap thats worried about the wiring. Heres a breakdown for 87-95 302/351 speed density trucks using a 88-93 mustang gt ecu. Now if you have a 302 you *may* need to change the firing order depending on your truck.
Maf Wiring
ABCD output
A - splice into pin 37. Its reference voltage and needs to be tapped into
B - splice into pin 40 or 60 of the ecu. its ground
C - add pin 9 of ecu
D - add pin 50 of ecu
Now for the major wiring of the ecu and pins to move.
truck pin 8 to pin 19 of mustang ecu
truck pin 11 to mustang 32
truck pin 51 to mustang 38
add pin 12 for injector 3 ground
add pin 13 for injector 4 ground
add pin 14 for injector 5 ground
add pin 15 for injector 6 ground
add pin 42 for injector 7 ground
add pin 52 for injector 8 ground
splice pin 29 and 43 together for hego. I didn't feel like adding a second o2 sensor right now since i did this mass air swap on a whim so i split the signal from pin 43 into pin 29. When i feel like modifying my exhaust and moving the o2 sensors into each bank i can run the signal return from the new left o2 to the pinout from 29.
Injectors 1 and 2 pinouts are correct. What i actually did was bought some high temp wiring in 6 different colors ran it in loom to the factory injector harness. I cut the ground wires for all injectors except injector 1 and 2 leaving enough room to solder new wire in.
the ecu i used was a cardone part number 78-4352. Cost me 80 bucks remaned. From fireguy's website it shows it to be similar to a a9l ecu for my manual truck and a 74-9502 mass air sensor off a mustang. A cone air filter clamps right onto the maf and i bought a magnaflow y pipe to merge the twin air hoses into 1 pipe. A trip to Race parts solution (racepartsolution.com) got me 2 silicone connectors to connect everything together.
2 hours worth of work.
200 dollars in parts
result:?
silky smooth idle and i mean silky. 15 mpg in the city vs 10 driving with an egg under my foot and awesome throttle response.
The truck has never run so darn good.
If someone was contemplating the swap. Hope this breakdown helps you if especially you're worried about the wiring part.
Speed Density to Mass Air Conversion & Parts List with Cost for Bronco & F 150 & EO4D in an 86 351W Source: by Kurt H at 2bigbroncos.org
etc.
MSD; a few of the good ole guys (not really old..lol, but good!) here have the MSD; so they'll give ya their advice soon
for now see my site for MSD @
http://www.broncolinks.com/index.php?index=395
for other systems;
http://www.broncolinks.com/index.php?index=227
Select A Category:
Crane
Davis Unified Ignition (DUI)
PerTronix
High Energy Ignition (HEI)
Jacobs
MSD
I'd piggy back it in; keeping orig TFI Sys in-place for emergency back-up; seen enuf aftermarket ign sys (as well as TFI) fail during bad times.
GL!
