Fuel pumps keep running
Shadow_D
Schenectady, NY
Ok folks time for my issues again...
I tried to search for my old post about this problem but couldn't find it.
Problem is, when the key is off the fuel pump will run on it's own. Ive been told to look for a bad ground or a shorted wire but I haven't found one yet. I've also had to replace the relays under the hood a few times over the years (6 or more times, I've lost count).
Someone also told me to look at the wiring under the brake booster but I just haven't had a chance to check yet.
Any other ideas?
YO D,
I think I replied to that other post with this;
Fuel Pump Runs w/Ignition Switch Off; "...If it stays running with the truck off, then most likely you have a bad fuel pump relay; EEC Relay hanging closed; If the EEC relay goes bad, it could be sending the signal to the fuel pump relay to turn the fuel pumps on;
One easy test for this is: Without the key in ignition, bump the starter over with the starter relay using a screwdriver. If it is the EEC relay, the truck will start without the key in the ignition..."
Source: by sackman9975 (Scott), Redwagon & miesk5
What Brand are those relays? Ck for socket/relay contact corrosion.
Here is the sequence to troubleshoot the wiring
I don't have a 90 wiring dia, but here is a Wiring Diagram in an 89 5.0, 5.8 & 7.5
Source: by my pal here, Seabronc@ http://broncozone.com/topic/20547-fuel-pump-wont-shut-off/
His reply to a SAME Q about; "...Seems the fuel pump does not want to shut off when the ignition is off. This is what was draining the battery..."
Seabronc replied; "...
The relay probably has the points welded. Here is a diagram of the circuit...."
See LINK for the diagrams
S
Shadow_D
Schenectady, NY
miesk5: Yea I remember you did reply but I just couldn't find the old post.
Those are the relay's I've replaced several times so something is causing them to short out, maybe a chaffed wire somewhere???
I guess I'll need to dig around under the hood to see if I can find this thing.
One thing that I might not have mentioned and forgot about until just now, about 3 or 4 years ago (truck hasn't been driven more than 500 miles in the last few years) my neighbor stopped me when I came home to tell me that my horn started blasting in my truck and had been for over an hour. When I investigated it the horns were hot and smoking so I pulled the battery. I checked everything and couldn't find a reason, replaced the now burned out horns and it hasn't done it since...
If yu have a multimeter and can use it; here are the diagrams;
Wiring Diagrams & Component Location Diagrams in 86-96 Bronco & Fords; Agree and enter year, make/model, etc.
Source: by Airtex at http://www.showmetheparts.com/airtexts/
go thru the year, make, model eng type Drill
then select:
Wiring & Component Locations
Engine
Fuel Controls
Part1 1; this will give you color codes of the wiring from IGN Switch to EEC Relay and then on to
EEC and FP Relays
I assume you have to remove NEG cable and prob + batty cables so batty doesn't drain and FP runs forever, right?
So with KEY off..
Put meter in 0 to say 50 volt DC range
Black (-) Meter lead on Good Ground on engine
Re (+) meter lead on the RED/Light Green (R/LG) wire at EEC Relay
re-connect battery
if you have 12 V DC on that RED/Light Green, then
EDIT
Check IGN Cylinder
If no 12 V at that RED/Light Green.
The RED ® wire from that EEC Relay then goes to FP Relay and that carries the 12 volts to close the FP relay
So, with Battery still connected
FP should not be running so far
Connect meter + lead to that Red wire To FP relay
Have someone turn key to start; Should get 12 Volts there
turn off engine & remove key
if 12 volts is still there; then EEC relay is hanging up (cloded)
S
Shadow_D
Schenectady, NY
Source: by Airtex at http://www.showmethe...s.com/airtexts/
then select:
Engine
Fuel Controls
EEC and FP Relays
So with KEY off..
re-connect battery
EDIT
Check IGN Cylinder
Well thats part of the problem... They don't always run. every once and a while I will walk by the truck and they will come on for a few seconds then shut off like they are trying to keep pressure. after a day or so the battery is dead...
See why I've been beating my head against the wall :lol:
ok,
Hook Batty up
insert key in IGN Cylinder..don't turn it
shake it. violently
if nothing happens, reach down to the switch itslf at the base of the column. Manually push the switch back and forth through the different positions. Push it all the way forward (or down) and see if it will engage the starter. If it does, then your ignition rod is probably bent, which can be remedied quite easily.
