you will have to look at the tag on the pass side of the front of the rear axle. the tag should read 3 L 50 xxxx. the L means limited slip. most customs are bare bones bronco's. or you could jack up the ass end and start the rig and see what happens....Do you know if a 1979 bronco Custom with a 9" 3.50 would have LSD?
