Clutch Linkage
Rainelk
Can someone help me out, I need the rod that attatches to the clutch fork. Is it called the "Clutch adusting Rod"?(V8)
Broncoholics
Broncoholics
Washington State
Call Bronco Graveyard or a few wrecking yards so you don't have to spend much on it. To tell you the truth, that part needs longer treads as the clutch wears out so you can adjust it without loosing the bullet shaped part that pushed on the clutch fork.
msgsnprtom
