flasher/blinker/turnsignal
Sparkytx
Hey everyone, help!! if you can. I just got a 79 bronco and trying to get the kinks worked out. i cannot get my turn signals towork. the bulbs are good, the hazards all flash. most have told me to replace the flasher, There is only one flasher under the dash!! everyone keeps telling me there are two, I can't find it. One person suggested that there might only be one flasher but it needed a heavy duty fuse?
thoughts??
Thanks Sparky!
Bronc76
There should be a flasher for the turn signals, have you checked the fuse? The harness that connects the chassis to column could be loose. Check for bad grounds or it might be the switch itself.
woody
NC
typically there are 2. its on the opposite side. pain in the but to get to mine ( 87 ) feel back there if you find it you may have to pull the fuse assy. Ford put 2 in so no matter what you have hazards. lol
Staff online
bigd1948
