1990 351 Smoke on start up
Hemlock
Fort Worth Texas
I have a 1990 w/a 351. When I start it up it blows white smoke from tailpipe. Not just a little a bunch. After driving a few miles it stops. If I drive everyday and often it does not do it as much. It is when it sits for a few days that it really starts to smoke. I looked under and have no drips or leaks. There is a bit of seapage fron the top end but I have been told that is just a gasket fix. What do you think?
Krafty
Ontario Canada
could be a leaky valve seal, on my 429 that had been sitting, after I put it in and started driving it, it would smoke alot at the start but easy up , but still not really stop. when I pulled my springs off I only had 2 out of 16 seals that were not completely destroyed, sounds like you might have one or two starting to leak.
muddrivermike
Texas Arp
That sure sounds like valve seals as Krafty said.Pull your plugs and see what color they are.see if they have indications from oil on them.Now I was told if you use full synethic oil even though you may be burning it,,You wont see anything out of the exhaust.But it isnt as simple as drain and refill it and thats it.You have to do it a couple times to get the old oil flushed out of the engine from the new oil,then when its all synethic it should work...I cant confirm this though.And its defenitly not a fix.
BroncoJoe19
New Jersey
White smoke is steam.
Condensation due to changes in temperature can collect inside the exhaust. You'll notice it more when you have a few days that there is a lot of dew.
As Joe said, white smoke is steam. If it's gone after a few min of driving then it's just condensation in the exhaust & perfectly normal, particularly in cold climates. If it *doesn't* go away then you need to look for the source which is usually a head gasket.
Black smoke is oil or fuel that generally comes from something like worn valve seals, piston rings or a carb that's running rich
Gray smoke is usually transmission fluid coming from something like a blown modulator valve.
BroncoJoe19
New Jersey
See that! I learn something every day.
Thanks :) /emoticons/[email protected] 2x" width="20" height="20" />
Krafty
Ontario Canada
also if it is infact steam, then that would mean that you are instantly boiling off coolant from inside your combustion chamber that seeps in from your leaky gasket when sitting.
50joe
Trenton NJ
Saw a cherokee blowing grey smoke once. Turned out it was brake fluid. Seal in the master blew, booster sucked it in, through the check valve, down the hose, into the intake. Only did it when you hit the brakes. Now THAT was a one in a million.....lol.
I had grey smoke that was engine oil. not black smoke
small amounts of oil usually look black, if it's burning a lot of oil the smoke tends to look more blueish. Old engine oil that has a lot of contaminants & old fuel (usually from worn rings) can do that but they're just guidelines & subject to interpretation :) /emoticons/[email protected] 2x" width="20" height="20" />
muddrivermike
Texas Arp
Hey ive seen that before,pretty funny when you dont see any brake fluid leaking,just it disappearing. :lol:
50joe
Trenton NJ
I thought she was nuts when she told me why she was bringing it in. Always learnin......
Lana Kane
