janroger64
- Joined
- Jun 9, 2009
- Messages
- 19
- Reaction score
- 0
New to this forum. Just did a major brake overhaul to my 74 Bronco. Changes the shoes, cylinders, springs, and all the hoses. After we were finished bleeding the system, the brake warning lamp on the dash won't go out...Have tried to reset the valve were the light switch is located as described in the shop manual (turn on ignition, press brake pedal and light will go off), but the light keeps shining :mellow: Anybody have a tip for me?? Maybe I have to dismantle the valve....Have checked the switch with an ohm-meter, and it seems to be ok. janroger64.
