type of transmission
bingen
Cebu, Philippines
Would anyone know what type auto trans this 59 Ford F100 with a 292 ci motor would be? I am in the Philippines and things are hard to get around here. I have a 66 Bronco with manual trans and would be nice to make into an auto. This set up I see has a motor, so I can take the carb with kick down rod, see if the flex plate fits into the 289, so with the converter. If its a C6, then all I would need to order with be the adapter to the D20
Thanks for any info
I doubt it's a C-6 in the 59 F-100, possibly a C-4 auto. There are some links and ID tech in the How-To &Tech Articles forum that may help you, or post a pic of the tranny if you can. You can often ID it by the bottom pan shape and bolt count, or look for the ID tag. JSM84
