broncogurl86
BroncoGurl
Hey boys,
I'm back with a new issue /emoticons/[email protected] 2x" width="20" height="20" /> . I will try to explain as best as I can. Here goes nothing, I recently have been having several issues with the bronco that I think I get solved but then a week later it is doing the same thing. :-&
Here is what it is doing right from the start.
First time- started bucking but touch gas and would even back out and drive fine then parked it and would not start back up come to find out that the sending unit shit the bed again it is only 9 months old . Replaced that and she fired right back up didnt have a problem for a day or two.
Second time- went to pick my kid up from school and she bucked again a couple times but again was able to give it some gas and leveled back out to normal for a little ways then the RPM's dropped down to nothing but was still running feathered the gas a little and RPM's went back to normal and drove fine. :wacko:
Third time- was driving normal when all of a sudden she died right out and would not start back up for nothing it was getting late at this point so i decided to let it sit over night and come back in the morning to try and figure out what the issue was. Got there in the morning and decided to try and move it to a level spot to work on it at and she fired right up and I was able to drive it home. Drove it for a couple of days and then it did the same thing RPM's went crazy and bucked a couple of times then dies right out but if I let it sit over night it will start right up and be fine. /emoticons/[email protected] 2x" width="20" height="20" />
Fourth time- this time she bucked a couple of times then RPM's when crazy and nothing I did made a difference and stalled right out and would not start back up til the next day.
I have replaced the sending unit, pick-up coil, ignition control module, cap and rotor, and the ignition coil, also put a new fuel filter on also.
She is definately getting gas you can smell it when you turn the key and we tested for spark and we have that but I am at a complete lose as to what it might be hopefully one of you have come across a situation similiar to this and can help me out or at least point me in a direction to start.
Happy Muddin
Broncogurl
Happy Muddin
Broncogurl
