love_my_bronco
i have two bronco's an 84 and an 86. i can only keep one.. and i want to know what axel to keep im gonna swap out stuff and not sure what i should keep.
Run a mini spool in that 9. There only 30 bucks. Just put one in my cousins truck last weekend and she works nice. Donies on the pavement all day.true but the 9 didnt come with limited slip option and getting a locker is both time and money that i dont have i ned to be on and off road so i need at least a limited slip.
I think the 9 inch " Limited slip" was called a Trac Loc. Way easier to swap out the pumpkin than the whole diff. Just make sure you find one with 3.50 gears. they are very plentiful in the auto wreckers, cheap tootrue but the 9 didnt come with limited slip option and getting a locker is both time and money that i dont have i ned to be on and off road so i need at least a limited slip.
A buddy of mine had a Vega that went 9.30 in the quarter, and he always insisted on running the GM 12 bolt, because he didnt want any Ford parts in his Chevy. He tore the ring and pinion teeth off a few times, due to the pinion deflection under load. He then sold the Vega and built up a 1400 hp ******* that goes high 7s. The first thing I said to him when I looked over the car.. "Where's the 12 bolt, dude?? That looks like a FORD rear in there!" And indeed, it was a 9" housing.9 inch is strongest rear end known to man. thats why all the chevy lovin dirt trackers run them they say it is bc it is easy to swap gears but they know a chevy12bolt wont hold up to any power or abuse.
