Extended Radius Arms
whtebronco
Poquoson ,Virginia
i have a skyjacker 8 inch suspension lift. on 38in swampers. what kind of extended radius arms will fit? i have look around at skyjackers and they are mad for the 4 to 6in lifts. they don't make brackets for the 8in lift?
Have you tried contacting Skyjacker? I know the ext arms for the 4"/6" kits use the stock brackets to attach the arms to the frame. I would think they might offer a short drop bracket to use with their ext arms. The drop brackets from their 4"/6" kits are made for the stock arms, and would likely be too much drop for the ext arms on their 8" kit. JSM84
