Vacuum diagrams
Matt_V
Have Bronco....need money.
Ok, so I've been sitting and staring at a vacuum diagram for my 351 for about the last hour... and I dont think I am any closer to figuring out these hoses than I was before I opened the Chiltons book... first problem is that it jumps from a 1981 351 to a 1983... so I just looked at the 81 model diagram.
What kind of degree do you need to read these things? I kept looking at the one that went from the distributor vac. advance to the carb...but according to the diagram there are all sorts of valves, etc there... I think? and not even sure if its supposed to go to the carb now.
I'm pretty much out of my budget this month for buying parts, so I figured I would work on electrical and vacuum hoses... but I'm confused! :huh:
BroncoJoe19
Hey Matt,
I'm not sure if I can help, but is it possible for you to scan what you have and post it?
Maybe a pic of your carb and stuff, and a scan of the diagrams you have.
IF so, please scan the diagrams at a relatively high resolution.
Matt_V
Matt_V
I'll have to see what I can do. One diagram is in the Chiltons manual, the other is under my hood. Both are hard to understand for me.
I'll try to take a picture or two of what I have under the hood and 'point' out with a photo editor what I am talking about. Might take me a little bit...
I'll have to see what I can do. One diagram is in the Chiltons manual, the other is under my hood. Both are hard to understand for me.I'll try to take a picture or two of what I have under the hood and 'point' out with a photo editor what I am talking about. Might take me a little bit...
That would be the thing to do. The Chilton's is just an example, the actual one for your truck is year, engine and sometimes specific to the region it was originally sold in. The functions are color coded and it is actually easy to follow once you understand the diagram layout.
Matt_V
Matt_V
Ok... bear with me. These are the photos that I managed to snap, and I know they aren't very descriptive...
This one is just kind of an overview of some of the ones I THINK I found where they went or were existing...
Here's a couple of '*******' that don't have any lines. And what are these sensors that are plugged?
More sensors on the other valve cover
From the Distributor to the side of the carb.. is this how its supposed to be?
And I know these aren't vacuum hoses, but can you identify these loose wires with plugs?
BroncoJoe19
Matt,
I wish I could help more.
Can you get a pic of your vacuum diagram up for us to look at?
Here is a vid on that if you look it in high quality resolution, you may find it useful as a little bit of a reference.
Matt_V
Matt_V
Yep. Here's a pic. I hope its legible.
This is the sticker that is next to the hood latch on my truck.
Redneck86
First On Race Day
Colorado
Your engine looks alot like mine used too. I took everything out that i could involvin vaccum lines and electrical. If you dont have to have emissions on it up there i would take all the emissions contol off and everything that goes with it and plug up or reroute what you have too. That what i did on my 86, its alot cleaner and easier to work on now it just takes time and look closly at what you do.
Matt_V
Matt_V
Yep. I would do that too but I don't know what it NEEDS to run and what it doesn't.
BroncoJoe19
I think you are going to need someone who has an operational engine like yours, have them send you some detailed pics.
Perhaps you can go to some car shows, and get lucky.
Here are the few answers I can give you.
Matt_V
Matt_V
Thanks Joe,
I knew the electric choke wasn't connected, I just haven't found the right wire that is supposed to go there yet.
Whenever I put a vacuum hose (with suction) on the EGR it killed the engine.
I dont think the middle hose is cracked, its a ridge on the outside that makes it look that way in the pic.
I've found someone with a Bronco (same body style) but dont know if it has the 302 or 351 yet. or the year model. Hope to find out soon.
Matt_V
Matt_V
Yes it will help out a lot if most of the vacuum locations are the same on an 82 351 and a 77 302? From the looks of it they are, so at least it will give me a good starting reference.
Where'd you find that?
BroncoJoe19
:) /emoticons/[email protected] 2x" width="20" height="20" />
All I can say is, when you are good to people, other people are good to you.
A certain amount of credit has to go to miesk5
I am glad that it may be helpful.
Hopefully my next topic will be more helpful... watch for it.
joe
desert4wheeling
Arizona
I HIGHLY recommend getting the EVTM for your year of bronco. Theres no better resource for tracking vehicle specific wires and vacuum lines. Im sure most anyone else who has one would agree. I got mine off e-bay. Just my two cents anyway.
Matt_V
Matt_V
I've been checking.. just haven't seen an 82 on there yet.
Matt_V
Matt_V
Found an 82 EVTM on ebay, so I got it... now just waiting for it to get here.
Hopefully it will help me out with all this mess.
The EGR requires controlled vacuum not a direct hookup. It is not supposed to function at all times. Your engine can get along just fine without it. The electric choke, on a stock Ford engine hooks to the alternator stator post which is 7 Volts. Do not hook it to 12 Volts it will burn up, ( a Ford better idea). If it is not the stock carb, then usually 12 Volts is the thing for it, however it must be a switched 12 Volts (not hot at all times, only when the key is on).
Matt_V
Matt_V
Got the EVTM today. Wasn't really what I expected, but I hope after I sit down and really 'read' it maybe it will help me out.
24Rocko58
