converting 302 to a 351
tjf
Brisbane, Australia
is it possible to do this?? I had someone tell me that it can be done by changing the con rods and crankshaft??? if it is possible, what will need to be done. also will i be able to do it without taking the engine out.
Thanks.
No you cant do that the biggest I think you can get with a 302 is a 347 but it will require the motor be removed and modified . A 351 can be stroked to a 427 :D /emoticons/[email protected] 2x" width="20" height="20" />
