Trans shiftin late and acting weird
88BroncoBlack
Chicago Suburbs
Hey guys I decided to change my trans pan gasket the other day because it was leaking, the kit comes with the gasket and filter, i changed the filter and gasket then refilled the trans, and it would shift manually by the column but if i was in drive it would just wind up and not shift out of first, i took everything back aprt again to make sure all the gaskets seated and such, then refilled again, no its a little better it will shift but at very high rpm, like if you are normally drivin down the road and it would kick down if you were at like 3000 now it wont drop down til like 4200 any ideas
BroncoJoe19
New Jersey
Sorry man, this is out of my league, but you may want to post specifically which trans you have so that when someone reads your thread who can help, they will be able to be more specific in their response.
joe
88BroncoBlack
88BroncoBlack
Chicago Suburbs
how can i tell what trans i have, i have to idea, i think its one of the C trans, because the auto store said thats what they think i have an the filter was the exact same
BroncoJoe19
New Jersey
It would be a C6 a three speed, or a AOD 4 speed overdrive or E4OD a four speed overdrive with a selectable OD on/off switch on the dash.
BroncoJoe19
New Jersey
How many quarts of fluid did you use?
Here is info from another forum on how to refill the trans.
Fill with 6 to 8 quarts, start the engine, shift through all the gears, shut engine down. Fill another 2 qts., let heat up, then to fill to final level.
Level should be between the cross hatch marks when hot at idle.
88BroncoBlack
88BroncoBlack
Chicago Suburbs
oh one other thing, my shifter has always been slightly off in the dash where it say P R N D 2 1, how do i get that lined up correctly, the guy i bought the truck from sai it has been like that since he had someone replace the steering column
coolio2281
Union City, OH 45390
if u mean the little needle is off a little on the dash telling u what gear u are in, if iam correct on my 93 bronco take your steering wheel upper and lower cover off and to the right, right underneath your gear selector lever there should be a little dial with a wire running though it and under the column and into the intstrument panel, u can just twist that dial clockwise or counterclockwise to adjust the needle
shift1313
VA
so how many qts of fluid did you use? Did you check the level warm after running through the gears like joe said? What kind of fluid did you use? It sounds like the clutches are slipping. If it is a C6 tranny you should have used type CJ fluid. Its specifically made for C6 tranny.
Utahstroke
