Transmission Passing gear
bidibronco
Norfolk Va
Well, the "new" engine is finally in and runs like a champ. The problem I'm having is when I mash the skinny the tranny doesn't seem to want to get into it's passing gear. It's the E4OD and I know there is a kickdown on it but I have absolutly no idea where it is or just how to fix it? Thanks to all who will help a bronco fellow out! :)>-
shift1313
VA
i dont have an e40d nor have i ever worked on one but the only thing i can think is maybe the vac line to the modulator isnt hooked up or it has a leak?
Check the HOW TO forum, I believe Meisk5 has a link to a video on how to adjust the kick down cable.
BroncoJoe19
New Jersey
Bidi,
The E4OD trans is computer controlled, I really do not think that there is a kickdown linkage of any sort. Try pulling codes.
Bidi,The E4OD trans is computer controlled, I really do not think that there is a kickdown linkage of any sort. Try pulling codes.
yea, good! IS the TCIL (Transmission Control Indicator Lamp; also called OD switch/LED) flashing?
anyway, get it scanned for DTCs and;
Shift Cable Adjustment for 92-96 Source: by Steve83
Trouble Shooting Flow Chart Source: by jasperengines.com via web.archive.org
"Pull codes
Most likely an engine problem - T.P.S. on gas engines - if a DTC comes up for this TPS; ck my site for fixes...my lap top is **** again
Possible valve body problem
or
LATE OR NO DOWNSHIFT ON COAST DOWN
Pull codes
Inspect & Troubleshoot solenoid pack and valve body"
Fryman22
