engine reving and transmission
weekendmechanic
I recently bought and 83 xlt ford bronco and its great but there is a problem the shifter is on the steering colum and is as P R N D 2 1 and when I put it in drive it takes off slow and then reves real high before it shifts into gear, I changed the transmission filter and oil, and it didnt smell or look bad, but then I am no mechanic, I need HELP
