Timing mark problem
Middaymassacre
Houston, TX
Does anyone have a timing mark like this? ive never set timing on one that only has a point. im guessing thats 0 but im not sure. And does anyone know what i should set mine to? its a 351m with stock ignition, a mild cam, dual plane low rise intake, and a 4 bbl 600 carb.
freak
Indiana
Can't see the number's on the balancer. When the hash mark's line up with the pointer that where the timing is at. Try and set it at 8 BTDC or in that area. All motor's are different you'll have to play with it.
89Bronco58
Jersey
do you know how to set your timing at TDC (top dead center) ? do that and then just slowly adjust from there, you wont need to use the timing mark, thats how i set mine, just make sure you dont advance it and make it pinp, thats very very bad for your engine
Wyatts86bronco
