Betty The Bronco
Whats the diffrence between the Overdrive button and the 4x4 button?
one button puts you in 4 wheel drive and the other button puts you in overdriveWhats the diffrence between the Overdrive button and the 4x4 button?
one button puts you in 4 wheel drive and the other button puts you in overdriveyou are kidding rite?
Yes, Betty, Blade is correct. The "OD" or overdrive button engages the fourth gear in your transmission to reduce engine RPM's and increase fuel mileage. The gear ratio is somewhere around 0.75:1, compared to 1:1 or higher for the other gears in 1st, 2nd, or 3rd. I would suggest leaving it on all the time for normal highway driving, The only time you should turn OD off is when towing a trailer. Towing puts more strain on the transmission and will burn up the OD on hilly roads.
The "Low Range 4x4" button is only for when you engage four wheel drive on non-paved roads. Four wheel - High range is good most of the time for gravel roads, mud, dirt trails, etc. When you need to crawl over rocks or go really slow, the four wheel low range will slow your speed down. The engine will still rev fairly high (2500-3000 RPM), but the 2.72:1 gear reduction in the transfer case will reduce your tire speed. Low Range is also good for pulling a stuck vehicle out or pull-starting a tractor or road grader. JSM84
Here is what the '96 Owners Manual says about your truck (if you still have the automatic hubs):My '96 won't shift into 4-High unless I'm stopped. I've got the manual 4wd with a shift lever on the floor. Are the newer Broncos supposed to be shift on the fly?
I have a digital copy of the entire '96 owner's manual but it is too large to post here on Broncozone. (3mb) If you send me a PM with your e-mail, I can send you the whole thing. It's also available for free from the MyFord Website.Thanks for the info, Roadkill. It's nice to see the owners manual because I purchased used and a previous owner lost it (or sold it on ebay!).
