Air intake
Betty The Bronco
goshen new york
I'm looking to buy a K&N FIPK system (website) http://www.jegs.com/webapp/wcs/stores/serv..._10002_10388_-1 But there is only one problem, as you can see the filter has two holes in it leading into the two rubber tubes which leads into the engine. But my bronco a 1994 5.0 (completely stock) has just one big rubber tube that leads into the (stock) filter. So my question is, am I the only one in this situation? and does the kit come with the two rubber tubes? if not could ya please tell me where I could buy the tubbing? Please and thank you.
LOVE, BETTY THE BRONCO
Roadkill
Killeen, TX
I think you are looking at the wrong part for your truck. The single round tube indicates that you have a mass air system, in which cas, you need part number 599-57-2510-1 on this page from the Jeggs site.
Here is a picture of the mass air sensor. If you have this component, you have mass air. This picture also shows the above mentioned part# installed on the truck.(This is a '96 Bronco with 5.8L, but the air intake is the same as the 5.0)
Edit:
On the stock setup, that metal housing (in the red circle) will be bolted directly to the side of the air cleaner box.
eholt80
