White90Bronco
- Joined
- May 2, 2005
- Messages
- 89
- Reaction score
- 1
My Bronco (1990 Fullsize, 302, AOD) just started leaking transmission fluid one night. First thing I though of was the cork gasket on the pan. Changed it to a rubber fiber gasket, no luck. Next, I retightened all the bolts on the pan in sequence, no luck. Then, I went to the guy who rebuilt it for me. He told me that AOD's in 4x4 vehicles are bad about leaking between the back of the tranny and the tail housing, so I should tighten up the bolts holding them together. Came home, did that, no luck still. He also told me that on the rare occasion the housing cracks and that would be why it was leaking. Came home checked it, not cracked. My Dad suggested that maybe the pan was bent. I took it back to the mechanic to have him look at it for me. The pan was bent, he fixed it, came home tried again, still leaking. It looks as if it is leaking between the two rear center bolts on the pan. Someone please give me more ideas on what it could be. This is my daily driver and I need it fixed ASAP!!
