wiring
gravelgerty
[i replaced the 3 speed in my 69 with an auto from a 73 including the steering column. My problem is with the nuetral saftey switch, anyone know the wiring? also , is the back-up light switch in the same harness? The old one worked off an external switch on the linkage. :ph34r: /emoticons/[email protected] 2x" width="20" height="20" />
The 2 black wires from the switch harness with a purple stripe are for your backup lights and the 2 red wires I think one has a green or white stripe are for the neutral safety switch , Hope that helps :D /emoticons/[email protected] 2x" width="20" height="20" />
79' Buckin Bronco
