why wont it run
John Eversoll
I rebuilt my 83 Bronco,carb, auto ect
I put the new motor in and wire everything up the way I took it out and it will not start....
It will in fact turn over as if it wants to start. It is getting gas and has spark! I lit myself
up just to see. Damn!! Any body out there have the answer!!
Thanks!! John
If timing is set right, you should consider rechecking all your ground connections, very easy to forget one. Try and remember where you removed them from and make sure theres a good connection. You have the ability to rebuild and engine so you obviously know what you are doing, but sometimes its the simplist thing that we miss.
Motormouth2025
