Whoops ! Tried to change the ECT sensor sheared off a tube on the
Kenan
Woodland Hills, CA
Hey all !
Newbie here dont know where to turn to. I tried to change my ECT sensor and as I was I sheared of a coolant tube (it was rusted out) and now have to change that. It has one line that runs up the intake then over to the radiator cap. Another steel tube runs and then connects to a coolant hose that runs to the heater. One of the metal tubes that is forged on this piece sheared off. I need to change that part any suggestions on the approach ? I have 5 days off so more than enough time to work on it just need some pointers if any one knows about the changing of this piece. Attached is the problemo.
yo KENAN,
WELCOME!!
Water Pump By-Pass 3-Way Tee (one leg runs to throttle body) Replacement & pics in a 90; "...An Agriculture Supply shop that builds custom crop sprayers had high temp plastic. One 1/2 inch T and one 1/2" to 3/8" coupler, new hoses, and new clamps..." Read more; Click next to view more
Source: by Supersanbob (Super Bronco) at http://www.supermotors.net/registry/17162/64929
Ford Motorcraft PN for for coolant outlet on lower intake manifold (has the port for the ECT sensor and tubes for
the heater core and TB is E8TZ-18B402-C TUBE ASY-HTR WATER
$86.26 at Ford http://www.fordparts.com/Commerce/ShoppingCart.aspx?addpart=E8TZ-18B402-C
E bay prices are lower, US $49.58
Throttle Body Coolant Line From Radiator; Top hose to the filler neck, bottom is the coolant source from the metal fitting that screws into the intake manifold (look where the heater hose and ECT sensor go, there's a 3/8-inch ****** on it the part # is F2TZ8555B for the 20" line and F2TZ8555A for the 24" line
& in case,
Bypass Hose 302, 351W
# 30645 $6.00 at Jeff's Bronco Graveyard
1980-96 Bronco
btw, Jeff at the Jeff's Bronco Graveyardhas offered a 2% discount to members of The BroncoZone for on line orders. To get your discount, enter the discount code BZMEMBER. Also you must include your BroncoZone User Name with the order.
