**** while driving
broncokenny
Ken Emerson
Allright we have seemed to eliminate idle problem everyone,but what causes a **** while driving
when I back off gas pedal anyone??? :huh:
---"what causes a **** while driving"----
Alcohol, cell-phones, & attitudes....! ... but that's a whole diff. story.
There is a bit of play in the rear diff. that can be felt when the throttle is dumped quickly.
This is amplified with a worn suspension/U-joints. "Axle-wrap" adds to it as well.
broncokenny
Ken Emerson
Thanx Im going to check that out too.I was waiting for someone to think roadjerk :))
broncokenny
Ken Emerson
No but that sounds a lot cheaper than a torque converter or new drive train Thanx
Didnt no it had one?
Now Im not sure I do have one.Ive looked all around and havent found it.Im not sure what trans
I have ? I know my book says only on c4,c5 & c6 have them.Should there be any play in my rear
drive shaft when I turn it by hand?Im getn frustrated :mad:
Yeah,
Looking at the yoke where it enters the seal on the pumpkin, e-brake on, & in neutral, ..... you should have 1/16 to maybe 1/8 inch movement.
Much more & there may be some issues (internal pumpkin)
Not uncommon & not a major expense.
ALSO, if you can move the dr. shaft up & down at the pumpkin, the torque nut may just be loose.
Rear wheels off ground (jack-stands) helps with inspection of rear-end & dr. shaft....but... there will be more slop due to no restrictions to movement.
Oh, ...the vac. mod. is on the tail cone of the trannie.
check the hose for cracks,etc.
broncokenny
Ken Emerson
Yeah,
Thanx for the info.Im go n to put up on jack stands now and check it out.
WileE7
look on the back of your transmission pan i have a c6 transmission mine is on the right side on the rear of the pan there should be a hose connected to it
bidibronco
Norfolk Va
I don't know what year your truck is but if you have a speed sensor in the rear end then that may have some shavings magnatized to it. Or, it may just be bad?
broncokenny
Ken Emerson
Now Im really bummed out.Not only do I still have ****.It has stalled out on me a couple of times,
when I stop at light etc... So after a hundreds of dollars later in parts and 2 different shops. Im
no further a long than a couple weeks ago.Ive replaced throttle cable,egr valve,u joints,had idle set,and throttle air intake valve.Anyother ideas????Checked vacum lines to trans,little play in rear end but not real bad. Yippie :( /emoticons/[email protected] 2x" width="20" height="20" />
1988 XLT with 302 ,4X4,OD Thanx
Hmmmm...,
Just so you'll know, "hitt'n the nail on the head" (solving problems over this electronic device) is raw science at best.
Now it sounds like a fuel press. problem, or even the ignition module.
Did you try Auto Zone...? They'll read the codes free ('96 & up)
'95 & below, one has to buy the code reader....about $30.00
whitey
North Hollywood, California
have you checked the coil? i had a problem where it would stall at lights rarely then start right back up. then it started doing it in the mornings everytime i slowed down but would start right back up. then one day it stalled at a busy L.A. intersection and wouldn't start. BTW- people in L.A. are a-holes noone would lend a hand while i pushed the beast out of the intersection- they just honked. anyhow- the problem was a corroded wire that leads to the coil. that fixed it then i replaced the whole coil. i hate car electrical stuff, it gives me fits.
broncokenny
Ken Emerson
1988 XLT 4X4 W/OD
[Thanx Ill check it out.I know what you mean.Ive lived in Detroit,Phoenix area,Boston area have
stayed in New York and LA a few times there is no worst traffic or driving conditions anywhere than L A. :excl:
79brnco
