broncokenny
Ken Emerson
Thanx to all who helped me with my 1988 Bronco XLT,changed,coil,solenoid,ignition module,distributor,cap,rotor,egr valve,throttle cable,throttle air intake,water pump,thermostat.Also lost firing
sequence,found it again,lost shaft for oil pump down in oil pan,fished out with magnet through oil pan drain hole.Have not checked everyones suggestions yet,but after all that I stll have some **** when I let off pedal.
I think Im going to take a little break. Im worn out Once again thanks to all who had suggestions. >-
