Wheel offset?
BroncoJJG
The 951, Cali
I want to get new rims for offroading in my bronco, but i cant find information on what the wheel offset is on the bronco.
fordfan22585
cape cod
depends on how far you want it to stick out. i have 15x10 with a negative back spacing so they stick ou ta bit
Replied to your original post:
http://broncozone.com/forums/index.php?showtopic=11325
For new rims, you want a minimum amount of backspacing of 3.5", but not more than 4.5", and 4" would be the limit for stuffing a larger tire than 33's. The reason is that a 33x12.50R15 tire on a 15x10" rim with 3.5" bs will rub slightly on the radius arms at full steering lock, and will rub the front bumper and front edge of the rear quarter panels without any trimming or lift. So, if you have a 6" suspension lift and 35x12.50R15 tires on that same 15x10" rim, you'll still rub the radius arms when turning. Some of the extended radius arms are bent inboard to give a bit more room, but I still rubbed on my 84 Bronco with the SkyJ 6" kit and longer arms. The farther your tires stick out, the sooner you'll rub something, JSM84
79' Buckin Bronco
