wheel base
koontreeguy
western mass
in the middle of installing a lift in the bronco. it came with extended radius arms and I was wondering if someone else has an 80-86 they could check the hub to hub measurements. I've got about 109" hub center to hub center on the side I haven't taken apart yet and I've been reading it should b 105 ish
K
koontreeguy
western mass
already looked around all over wiki and a buncha other sites. just wanted a couple people ACTUAL hub to hub measurements. I guess if I keep both sides pretty dead on it should b ok :) /emoticons/[email protected] 2x" width="20" height="20" /> but I still feel like I need to know haha
There will probably be some minor differences from vehicle to vehicle, but yes, as long as it is close and you keep both the same you should be OK. I'd go out and measure mine, but it is cold out there. 104 - 105 is about right. The specification for 80 - 86 is 104. It could be that someone before you may have done something to change the measurement slightly.
K
koontreeguy
western mass
but make it at least 5" longer ?
Let's try to verify that this 92 Bronco Frame Dimensions Diagram is = to toher years LESS the Front Crumple Zone.
by Ford via Steve83
it is in MM
See the Hot Link for other frame info including Frame Service - Drilling / Welding, etc. Precautions
Wondering if the extended radius arm install by a previous owner or shop was done.... kinda off, thus moving the wheels <_______> ??
K
koontreeguy
western mass
maybe it's a mini bronco centerion :) /emoticons/[email protected] 2x" width="20" height="20" /> I know the wheels were dead center in the wheel wells and no trimming was ever done to the fenders either. the truck had a stock suspension before I started lifting it and had all the rivets and everything. as long as I keep the wheels centered in the wheel wells and have = measurements on both sides I should be okay , correct ??? it's an 86 also, but I'm sure it dosent matter unless it was a 66-77 ---- and in my original post I meant that the KIT I bought came with the extended radius arms, sorry about the confusion
yo, LOL
Maybe...a mini C.. never know.
re; "keep the wheels centered in the wheel wells and have = measurements on both sides I should be okay"
Yep.. take measurements w/tires @ same PSI...
same for frame to be sure it wasn't hit in a prev owner mishap.
GL!
Similar threads
T
Replies
Views
1K
Top stories on BroncoZone.com
T
T
Replies
Views
1K
T
T
Replies
Views
1K
T
T
Replies
Views
1K
T
Ford644
