84AZbronco
- Joined
- Jan 18, 2005
- Messages
- 3
- Reaction score
- 0
I recentley purchased a 84 full size bronco.(351) (2 barrel motor cafrt carb) I was was aware this big rig would not get the best gas millage on the road but what i have experienced in my first couple of tanks is outragous. I was always told to expect about 12 mi a gallon. my first full tank i drove till i ran out and it turned out to be a little over 10 mpg. but in my last couple tanks its been coming out to more like 8. my engine is re-built with less than 5k mi on it. my tires are well inflated, the spark plugs and air filter are realitivly new and clean and i regularly use the fuel system cleaner. I can not figure what would **** my gas milage so bad. there are no gas leaks or hloes in my mufflers as far as i can tell. there is one verry small hole at the verry end of my left exhaust pipe right where it curves 90 degres to the left but besides that the rig has no obvios problemes. im looking for sugestions for posibilys to hidden things that can **** my gas milage. perhapse the card is just sucking to much gas and needs ajusting? any oppions and suggestions welcome! also i curunly have 31 inch tires and want to get some 33's will that size tire rub with no lift of any kind? thanx , 84azbronco
