What would happen if....
fbrown3
West Virginia
I think you would be pretty much at the limit with the 30's and 4:10 gears from all the info I have read so far. I am running 235's right now w/4:10 gears and I am pretty sure 30's will be my max.
Actually not a thing. That would put you in the center of the recommended RPM range for a 55 MPH cruise speed. You would be running about 2550 RPM at 55.
Do i want a higher ratio for 33s then?
25700[/snapback]
It all depends on how you will be running. Is this a daily driver with occational off road? If a daily driver, what is your normal highway cruise speed? Also, if it is a daily driver do you want to be on the economy end of the RPM range, the power end or a comprimise between the two?
bluesman17
bluesman17
Spam Terminator
South Bend, Indiana
its a daily driver with some offroading i usually only hit 55-60 unless im on a interstate then its 70. i probably want something midway between econ and power
Staff online
TrishC
