What transmission should get!?
gert73
What kind of transmission should I get for my 85 bronco. I'm buying a new 302 to replace my 6I. I still want to have it four wheel drive.
Unless the one you have is bad, keep it. What transmission do you have in it now, C6 or A4OD? If it is a C6 you will have P N D 2 1 on the shift indicator. If it is a A4OD you will have the a D with a O around it plus D 2 1. Either one should bolt up to the 302. Also, are you going to have it carbe'd or EFI'd? That makes a difference in the linkage hardware for the kickdown.
cjbronco
Jersey Shore
I am upset to hear that your only replacing the 300 w/a 302. If your going through the trouble of the swap, at least make it worth it. As far as tranny goes, if you have a auto I'd say a c6, and if you have a manuel, i'd with out fail say a ZF. Good luck either way :)>-
Ford644
