What Kind Of Oil/filter?
avp12304
sorry about the dumb question but I forgot which type of oil to put in my bronco and i was wondering whats the recommended type of oil for the 5.8L v8, its a 96 bronco, and also what kind of filter to use, thanks
hawk2100n
Wants Overdrive
i dont know what kind of oil filter you need but the oil that you use depends on you enviroment. i personally use full synthetic 10w 20 because it is always hot. but if you live up north you should use something different. usually at walmart there is a chart that will tell you what to use. also the synthetic will go for 8000 miles before a change versus a blend that might only last 3000-4000 mi. as for oil filter, take your old one off and you might get lucky and it will have a code on it.
drcarter0734
McKinney, TX
Motorcraft Oil Filter and Royal Purple oil. Used to use Valvoline religously. Will probably go back. Royal is too expensive.
Desert Donk
Castrol 20-50 and a K&N filter. In the past I have used the 2 quart filters from NAPA during the hot summer months in Phx. My inline 6 takes 6 quarts of oil with a filter change, but with the 2 quart filter it takes 7. My thought here was extra cooling but I don't always do that every year. I'm just inconsistent with that.
The sticker under the hood of my 96 5.8 recommends 5w-30, and the filter is a fram XG2 (xtra guard) DG2 is a double guard but just get the i belive the normal on is a PG2, this is just for fram filters. I know they carry motorcraft filters at the walmart here, I would just run one of those, fram, or purolater, or K&N I would just buy a quality name brand filter.
A
avp12304
hey thanks a lot andersson, i'm gonna throw the 10wd30 in her
Kingdalt777
