what is this thing
bart6180
elyria,ohio
I have an 89 eddie bauer edition, i was under the dash today and behind the passenger side kick panel there is a black plastic box approx. size of the ecu. it has a red light on the side of it, and when the ignition is on if i press the white button the light comes on, and stays on for 1 to 1 and a half minutes than shuts off.
does anyone have any idea what the **** this thing is
That may be the 4WD test module/shift relay if you have the push-button transfer case.
bart6180
elyria,ohio
ok guys its the t-case controller, my inertia switch is under the driver side dash by the brake pedal
thanx for your help
