What 4x4 Rims-Wheels fit 5 lug Bronco
ski.dive
Post any Cross-Reference 4x4 Rims-Wheels that will fit 5 lug Bronco
Yo Ski,
Wheel Bolt Patterns:
Bronco, Ford (& many makes)
Other vehicles with 5 x 5.5 in. (139.7mm) spacing & 1/2 in. NF lugs are:
Dodge: Dakota ('05-on), Durango ('04-on), Ramcharger ('79-83) 15 x 6.5 & ('88-93), Ram 1/2 Ton 2-&4WD ('79-83) 15 x 6 ('84-01) 16 x 7, Ram 3/4 Ton ('79-93) 15 x 7, Ram Van ('85-96) 15 x 7
Ford: Bronco ('66-96), F100 & F150 ('54-96), E100 & E150 ('70-09), M151 Mutt Jeeps ('59-78 ), all ('28-48 )
Geo: Tracker ('89-on)
IH: Scout
Jeep: CJ ('46-85) 15 x 4.5/5/6 (-20~0mm offset), FS truck & wagon (up to '72) & Jeepster Commando ('67-74)
Kia: Sorento ('03-on) 16 x 7, (-3~0mm offset), Sportage ('94-02)15 x 7 (-3~0mm offset)
Lincoln: all ('52-60)
Mercury: all ('39-51)
RollsRoyce/Bentley: Silver Cloud/Phantom
Suzuki: Samurai ('86-93), X-90 ('96-98 ), XL-7 ('01-on) 15 x 6 (10~15mm offset), Vitara/Geo Tracker ('98-on), Grand Vitara ('99-on) 16 x 7 (-20~0mm offset), Sidekick ('86-97) 16 x 7 (20~30mm offset)
Willys: pickups
But the BACKSPACING on each of those may vary, so spacers might be required.
by Steve
More..
Source: by Dave Williams at http://www.bacomatic.org/~dw/library/txt/wheelpat.htm
5 on 5-1/2 (139.7 mm)
AMC - Jeep (5 bolt) '42-'89
Chrysler - 8 cyl. & wagon '46-'55
- Imperial '54-'66
Ford 2 ton van
Ford Bronco, F100
Ford - all '28-'48
- full size P.U., van, Bronco '49-'89
International Scout, Travelall
Lincoln - all '52-'60
Mercury - all '39-'51
Suzuki - Samurai '86-'89
How To Measure Bolt Patterns
http://web.archive.org/web/20110104082054/http://www.wildhorses4x4.com/product/Wheel_Bolt_Patterns/tech_faq
Also:
"...Dodge 16" rim can be made to fit a Ford..." read pic captions
Source: by Steve83 (Steve, That dirty old truck) at http://www.supermotors.net/registry/media/744829
And last by our late Good guy friend Randy,
Hummer H1 Modification & Installation in an 94
Source: by justshootme84 (Randy Z, Casual Mudder) at http://www.supermotors.net/clubs/superford/vehicles/registry/1133/57018
RIP Randy
M1llionb
Houston, TX
FYI
I did my own research prior to getting a set of wheels from craigslist and they didn't fit my 86 bronco.
They were aluminum aftermarket wheels that belonged to a 01-03 F-150. I looked online to determine bolt patter for 86 bronco and for F-150 and they both shared same pattern. Once I bought them, took them home, attempted to mount them they did not fit. I searched multiple sources prior to purchase but I guess not all internet information is correct.
M1llionb
Houston, TX
These where the wheels I purchased (which I still have). The bold pattern was off by just a bit, maybe a cm.
Wihill
