weird camber/ ifs issue
Gerrad Reynolds
Northern Colorado
So I have encountered the most annoying and most difficult issue I can think of so far. When I drive the Bronco the wheels act as if they had a bent axle... as in the camber is positive then goes negitive then positive and so on when the wheels turn while on the ground. However if I jack the front end up and spin the wheels they spin true and dont wobble or have any sort of play in them. I replaced the drag link and tie rod ends. It doesnt have a good alignment and the tires are old but whenever I try to fix the alignment it does nothing to fix this. It is noticeble when driving as the front car moves up and down like a bobbing motion. 20160521_1236211.jpg20160521_1242491.jpg      the first picture is before I moved it and the second is after moving it about half a wheel rotation backwards
1. Don't drive this truck
2. Get it towed to a shop that understands Bronco front end suspension
Travis88
Im having the same issue on my 88. By chance did you figure out what was wrong?
